RumlogNG and WSJT-X TCPIP IC-7610 setup audio ?
DK3DUA
Unread post by DK3DUA »
I have followed these instructions
https://dl2rum.de/RUMlogNG/docs/de/pages/WSJT.html
RumLog can control the TRX, WSJT-X via the localhost:7374 of RumLog too, so far everything is ok
But how do I get to the audio devices of the TRX?
Is there anything missing? Perhaps the "Without Wire" tool?
And would this solution (whatever you should use) for audio via TCPIP also work with such
somewhat sensitive modes as FT8 Superfox?
Under Windows there is a tool "tweaktime" where you can adjust the PC time in small steps back and forth for
optimal adaptation to the time shift of the received signal (works great), is there also something like this
for the Mac ?
P.S. Just tried "Without Wire" ... yes WSJT-X now gets the audio stream , but .. I have to listen all the time to FT8 audio
because it only works if Macbook audio is not muted ?
Thanks and vy 73
Thomas
DK3DUA
Re: RumlogNG and WSJT-X TCPIP IC-7610 setup audio ?
It's all integrated in RUMlog. See Menu-->Transceiver-->Audio #1/2. You just have to create virtual audio cables using a tool like Sunflower or BlackHole.
https://dl2rum.de/RUMlogNG/docs/de/page ... erver.html
DK3DUA
ok thanks, I can RX/TX now with WSJT-X via TCPIP/LAN/Blackwhole :-)
I only have to adjust the TX level, even with TX power far below 100% output I can still see other spikes to the right and left of the TX signal (on the scope display IC-7610). This is not the case with USB.
Make sure you have set Audio to 16 bit.
DK3DUA
I found no option to set audio to 16bit on Macbook Air 2025 ?
In the TRX Preferences
DK3DUA
ok thanks :-)
