MacOSX El Capitan LOTW in Crash versions 1.5.13 and 2.0
n0uk
Unread post by n0uk »
Good morning all.
I have been using RumLogNG for a while now happily but have starting experiencing a hard crash every time I try to download from LOTW.
Whether or not I have the Read from ARRL box checked or not, the whole rumlogng app crashes whilst performing the processing of QSL's from LOTW.
This had been working well but I think this may be the first time I have done so since upgrading the OS to the new El Capitan version. I have run the Disk Utility and a manual fsck in single user mode to ensure there is no disk or file corruption.
Wondering whether anyone else has started experiencing similar behaviour?
73 Chris, N0UK, G4JEC
dl7vdx
Re: MacOSX El Capitan LOTW in Crash versions 1.5.13 and 2.0
Unread post by dl7vdx »
I have the same effect. with each pick of LoTW QSLs crashes the logbook.
Ron, DL7VDX
When it stopped working? Do you made changes?
Please check Console for correlating messages.
Go to the RUMlog preferences under the LoTW tab and set the "Last QSL in date" to a newer date. (Or use the date for tomorrow) Maybe there is a recordset causing trouble.
n0uk
Good evening, Tom.
Thank you for the suggestion to advancing the date in the Preferences/LOTW tab. That seems to have corrected the problem and I was able to download LOTW updates without the crash.
I had not made any other notable changes to any settings but your suggestion did indeed help.
Thanks again and very 73
Chris
Good to hear the fault is gone, but you may miss now QSLs. Do you remember the date was shown before? Now you have to go further into the past to find the point where it crashes again, all you have downloaded all QSLs.
dl7vdx
Bei mir funktioniert das zurückstellen des Datums leider nicht. Nennenswerte Änderungen, außer El Capitan, habe ich nicht vorgenommen.
Du sollst das Datum auch vorstellen, also näher an heute. In der Konsole muss doch ein Crashlog zu finden sein.
dl7vdx
Ja, habe mich nur unglücklich ausgedrückt. Ich habe wie vorgeschlagen das Datum vorgestellt. Dann habe ich es schrittweise wieder in die Vergangenheit gesetzt. Irgendwann beginnen dann wieder die Abstürze.
Ich habe ein crash-log angehangen, wenn du möchtest, kannst du auch gerne per TeamViewer auf meinen Rechner schauen.
crashlog-rumlog.txt
crashlog
(68.7 KiB) Downloaded 583 times
crashlog-rumlog.txt
crashlog
Ah, danke.
Zugriff auf deinen Rechner nutzt mir erst einmal nichts. Aber wenn du das Datum eingrenzen kannst, schicke mir doch bitte den Datensatz von hier: https://lotw.arrl.org/lotwuser/qsos?qsoscmd=adif
Wenn du in RUMlog die QSO Details nutzt, bitte auch mit auswählen.
Idee: Wenn du QSO Details nicht ausgewählt hast, crashed es dann auch?
dl7vdx
Es stürzt mit und ohne QSO-Details ab. Morgen grenze ich das Datum ein und melde mich wieder.
Wie ich von lotw einen Datensatz rausholen kann, muss ich auch noch herrausfinden :)
