Trying to let RUMlogNg to QSY and control JTDX
f5ukw
Unread post by f5ukw »
Hello Thomas,
(Again, really appreciate your outstanding work)
I'm trying to control JTDX from RUMlogNG, which means, when I ask him to QSY I was hoping JTDX Would do it as well :D
I tried to follow this procedure: https://dl2rum.de/RUMlogNG/docs/en/pages/WSJT.html but documentation is probably a bit outdated.
Sending QSO from JTDX to RUMlogNG was easy, trying to control JTDX from RUMlogNG is still a challenge.
Thanks for your help
Attachement may help to understand my issue, and what I'm doing wrong
CAT TCP setting
CAT TCP setting
Trying to QSY from RUMlogNG but nothing happen
Setting on 192.168.1.20 on JTDX
Re: Trying to let RUMlogNg to QSY and control JTDX
RUMlog doesn't have any CAT control in your setup! You haven't selected any transceiver model.
  1. Get CAT control working
  2. Connect external apps to RUMlog
f5ukw
DL2RUM wrote: Mon 23. Jan 2023, 17:26 RUMlog doesn't have any CAT control in your setup! You haven't selected any transceiver model.
sorry you mean setting TX like this?
What do you mean "Connect external apps to RUMlog"?
The best approach is to let RUMlog do the CAT control. Other apps control the trx via RUMlog.
Can you control your trx via network as selected?
f5ukw
DL2RUM wrote: Mon 23. Jan 2023, 18:21 The best approach is to let RUMlog do the CAT control. Other apps control the trx via RUMlog.
RUMlog can't just tell WSJT-X/JTDX to switch on specific frequency / mode ? Like would do TCI protocol for exemple?
JTDX control TX on PC (ip1)
RUMlog is just keeping log updated (ip2)
I only wish I could make switch and QSY JTDX to appropriate QRG selected on ClusterView for RUMlog
As far as I know, you can't do this. WSJT-X doesn't support TCI.
f5ukw
WSJT-X/JTDX are supporting nicely TCI
I'm using it with ExpertSDR3 and FT2000
Can't find it in WSJT-X. You never mentioned ExpertSDR! Then you can connect direct to it from multiple clients.
f5ukw
I have 2 JTDX instances
One running with TCI protocol and being controlled with ExpertSDR
the other one is using regular CAT control for FT2000
the one I was in need to control was the FT2000
Seems it's not possible for now.
Take care
It's possible, RUMlog just needs the CAT control.
