I'm using since a couple of days 2 transverters for VHF and UHF. With the transverter offset option /setting in RUmlogNG this works great. But... the transverters have a different offset. 116MHz for VHF and 404MHz for UHF
What I did: I use TRX#1 settings for VHF and TRX#2 for the UHF settings. I can switch between these to transverters by disable TRX#1 and enable TRX#2 for UHF etc... for VHF. This works fine for me!!
The only question I have is, is this the best way to do or is there an other easier way to switch?
Thanks, Vincent PE2V
Transverter setup
Transverter setup
Re: Transverter setup
Ok, I found an other option to do; save the setup in the presets.... yes. More easy
> Preset 1 144MHz offset 116MHz
> Preset 2 432MHz offset 404MHz
EDIT: the Transverter# On/Off is not saved in the preset. Is this possible? Absolutely not necessary but for lazy people
How it works now 1) enable Transverter in the Transceiver menu and 2) select 144MHz or 432MHz in the Transceiver preset menu.
Thanks!!
Thanks!!
