Transverter setup
PE2V
Transverter setup
Unread post by PE2V »
I'm using since a couple of days 2 transverters for VHF and UHF. With the transverter offset option /setting in RUmlogNG this works great. But... the transverters have a different offset. 116MHz for VHF and 404MHz for UHF
What I did: I use TRX#1 settings for VHF and TRX#2 for the UHF settings. I can switch between these to transverters by disable TRX#1 and enable TRX#2 for UHF etc... for VHF. This works fine for me!!
The only question I have is, is this the best way to do or is there an other easier way to switch?
Thanks, Vincent PE2V
PE2V
Re: Transverter setup
Ok, I found an other option to do; save the setup in the presets.... yes. More easy ;)
> Preset 1 144MHz offset 116MHz
> Preset 2 432MHz offset 404MHz
EDIT: the Transverter# On/Off is not saved in the preset. Is this possible? Absolutely not necessary but for lazy people ;)
How it works now 1) enable Transverter in the Transceiver menu and 2) select 144MHz or 432MHz in the Transceiver preset menu.
Thanks!!
I will add it with the next update.
PE2V
DL2RUM wrote: Fri 2. Jul 2021, 09:47 I will add it with the next update.
Thanks!! :)
