JTDX->RUMLog->DX Spots 30m fails
N5HC
Unread post by N5HC »
JTDX v2.1.0-rc151
RumlogNG 4.7 (408)
Wire shark shows UDP packets from JTDX with the correct information for all bands.
Rumlog does not populate the DX spots windows if the frequency is 10,136.00 MHz (30m)
17m and 12m works fine.
Older version of WSJTX have the same behavior, Rumlog does not show 30m UDP spots in the DX spot window.
N5HC
/Conny
Re: JTDX->RUMLog->DX Spots 30m fails
Do you have assigned this frequency to the Data sub band in the QRG preferences?
N5HC
Do you have filtered out 30m spots?
