Some minor bugs to fix
IV3TMM
Unread post by IV3TMM »
Hi Tom, here under a list of some minor bugs to fix. I found them and i write you a list with pictures.
I ask if you can correct them.
Ciao and thanks.
1) Can' t login automatically on my DXCLuster S50CLX. After connection cluster is waiting for my callsign after the word "login:" (Picture_1)
2) In database, the field "id" appear and disappear in random mode, even if it is selected (Picture_2 and Picture_3)
3) In database, when i input a qso, the fields NAME, QTH, NOTE, LOCATOR, MANAGER and OPERATOR are not copied from the previous qso but from the first qso. Some fields are not copied or populate like NOTE and OPERATOR even if
thery are selected to be copied from previous qso (Picture_4, Picture_5 and Picture_6).
I done an example. Starting with records 15533-11547-11937-11941-11947-11932-11934 i inserted then records 11950 and 11951. You can see which fields has been copied or not copied and from where
4) Field OPERATOR and USER_4 can not be checked (Picture_4)
5) Field NOTE can not be ordered increasing or decreasing like field NAME, QTH ...
6) It' s possible to have the field TIME in format HH:MM ? I create one of the four field with the ADIF TIME_ON (Picture_4), and this is in HH:MM:SS format. Two formats for the field TIME, may we have a unique format ?
Could you give the possibility to select which format time we want under settings-preferences like the data format ? This will be fine. Personally i' m not interested in seconds, only hour and minutes.
7) If you input a qso with a callsign that it has been worked before andf then immediately you filter your database with the filter field "callsign"under the window database (on bottom), sometime the last qso inserted does not appear in the window search mode and the first yes it appears. You have to exit RUMLog and reenter, then filter mode works fine with all qso.
8) Could you give the possibility for each data on every field to be selected on right, middle or left column place ? Name field (subject) is good on the middle of the field.
OK for now, please have a look and tell me if you need some more informations.
Your software is very interesting.
Ciao and thanks again.
Ciao de Francesco
IV3TMM
IV3TMM
Re: Some minor bugs to fix
Here other pictures.
Ciao de Francesco
IV3TMM
Thanks for the report. I was away for 10 days, here the first results:
Here it works, but maybe I'm using another address? I use s50clx.infrax.si
This field is not for general use. Somebody wanted to have some kind of numbering, so it appears in the main logging table only.
Fixed.
Fixed.
Fixed.
It could be possible to add these functions, but I don't like to add to much options for the user.
I was not able to duplicate this yet. When it happens again, just press cmd W. This should help.
IV3TMM
Hi, thank you Tom for the nice update.
Ciao de Francesco
IV3TMM
