Posts: 2994 Joined: Mon 27. Aug 2007, 13:36
Unread post
by DL2RUM » Thu 12. Feb 2015, 00:02
Can you try to connect the TRX to Fldigi? You have to swap both Fldigi related CAT check boxes
Good trick: tcpdump -nnvi lo0 port 7362 but don't work here. What I have to do?
tcpdump: lo0: You don't have permission to capture on that device
((cannot open BPF device) /dev/bpf0: Permission denied)
MBA13:~ dl2rum$
kf5jra
Posts: 38 Joined: Wed 25. Dec 2013, 20:06
Unread post
by kf5jra » Thu 12. Feb 2015, 19:49
DL2RUM wrote: Can you try to connect the TRX to Fldigi? You have to swap both Fldigi related CAT check boxes
What is odd is that with RUMlog fldigi follows the VFO. This only happens with RUMlogNG.
MBA13:~ dl2rum$
run that with sudo.
Unread post
by DL2RUM » Thu 12. Feb 2015, 20:49
What happens, when you disable all the TRX CAT and uses Fldigi for CAT? You don't to set up Fldigi for CAT, frequency exchange should work in both directions.
kf5jra
Unread post
by kf5jra » Fri 13. Feb 2015, 16:49
This did not work with RUMlogNG. I am out of ideas
-Ron
Unread post
by DL2RUM » Fri 13. Feb 2015, 16:57
Me too! Anybody else reading here?
Can you check the Console for messages from RUMlogNG?
kf5jra
Unread post
by kf5jra » Sat 14. Feb 2015, 00:06
Don't hate me for this but I moved RUMlogNG and Fldigi to a different computer and all is working perfectly. New computer is running 10.10.x where old computer is running 10.9.x.
Go figure. Thank you for the rapid response and guidance.
-Ron
Unread post
by DL2RUM » Sat 14. Feb 2015, 09:29
