QSL defaults
VK4DX
QSL defaults
Unread post by VK4DX »
Can the QSL flag defaults be changed?
Currently for all QSOs that I log the default is QSL: W, LoTW: W, eQSL: W. I'd like to have this QSL: -, LoTW: W, eQSL: -, (see the 2nd screenshot)
Also, when I'm in logged contacts window, I can change this by editing one QSO at a time, I'd like to be able to do it en masse, i.e. for multiple QSOs at once. (see the 1st screenshot).
Is this something that can be done and I'm not aware, or could this be a future feature?
Mike VK4DX
Re: QSL defaults
You can not change the status for multiple QSOs at a time. This is potentially dangerous for your logbook. It should be possible to manipulate your logbook database using a SQLite tool.
To change the default values, just overwrite the existing. The trick may be, to tab into the field or delete the current entry before you enter a new one, since a single character only is allowed in these fields.
At start up, the last used values will be used again.
VK4DX
Re: QSL defaults
Brilliant! Thanks heaps for the tips.
Cheers - Mike
