RUMlogNG version 2.4
Version 2.4 is ready for download and is already available in the Mac App Store: https://itunes.apple.com/de/app/rumlogn ... 4561?mt=12
  • Fixed: Crash during Cabrillo output when using OS-X 10.9 - Tnx OE1HXS
  • New: You can add data from HamQTH.com or qrz.com to logbook entries: Menu-->QSO-->Add QSO data
  • New: All band tables in the dx-spot window include now a contextual menu in the header to show/hide columns
  • New: Search Entities Window: Select one or multiple Entities in the result table to mark appropriate QSOs - Tnx EA5FY
  • New: Print QSL label: As alternate, you can select the last free label for the first sheet to print - Tnx SQ2KLU
  • New: Dymo Label 57mm x 32mm now optional with one QSO and two footer rows
  • New: DARC 10m Contest
  • New: North American QSO Party
  • New: REF Contest
  • New: Brandenburg-Berlin Contest
  • New: CQWW 160m Contest
  • New: UBA DX Contest
VA3AMX
Re: RUMlogNG version 2.4
Unread post by VA3AMX »
I'm having trouble to upload QSOs to LoTW after the latest update. RUMLogNG version 2.4 (81)
When I try to send a QSO to LoTW I get the following message: "tsql Sandbox Error. Start tsql manually first and reset path setting in the preferences"
I did what the error message said as well as restarted the computer but no luck.
Any clue?
Regards,
Eric - VA3AMX
I don't know, why this problem pops up now. Other users are affected, but not all. Maybe Apple changed security mechanisms which became active after an app update.
Make sure, the tqsl app is located in the Application folder. This ensures it has the correct user privileges.
VA3AMX
Thanks for replying. I believe my "issue" is solved after reading your note.
My TSQL application was not running from Application folder - I install and run my ham apps from a different folder.
So, I moved the TSQL app to Application folder and launch it from there one time to register into security mechanisms.
Then I closed and opened RUMLogNG, updated the Preferences for LotW to config the application path and the .tspl folder.
Once these steps completed, I selected a QSO and submitted to LoTW without errors.
Thanks for your tip to have the TSQL located into the Application folder. I never had issues running apps outside application folder.
Anyway, I believe the newest Apple security updates are tightening things up.
Again, thank you for your time and hope this clue will help others to fix this issue.
Have a Merry Christmas and Happy New Year.
Cheers
Eric - VA3AMX
Tox for feedback Eric. There is already a note in the FAQ: http://dl2rum.de/RUMlogNG/docs/en/pages/FAQ.html
