LOTW won't quit "processing" for 60m QSL
K7RAN
Unread post by K7RAN »
I successfully worked and QSL'd (LOTW) a contact on 60 meters. Now every time the RUMlogNG checks for new LOTW, it goes back to the "processing" for that same contact. I also notice that there are no DXCC tallies within RUMlogNG for 60 meters. Three questions:
1) How can I fix the "processing" that same QSO/QSL problem for this 60 meter contact?
2) Will this continue to happen with each new 60 meter incoming LOTW QSL?
3) Can RUMlogNG begin tallying 60 meter contacts for DXCC listings within the program?
Thanks and 73,
Randy K7RAN
Re: LOTW won't quit "processing" for 60m QSL
Does this mean, you download the same QSOs each time?
Is the setting "Last QSL in date" in the preferences changing after the download?
Could you try to manipulate this date and set it further to the future?
K7RAN
That fixed it! Thank you again. 73,
Randy K7RAN
