RUMlogNG crash after sleep
KT5V David
Unread post by KT5V David »
Hi Tom - I'm really impressed with RUMlogNG. The P3 control is already a favorite new feature - great job.
I have problem though. I'm using 1.0.7, but have noticed this since first release. Whenever I return to the station after the mac has gone to sleep, the program is up and running, but CAT is stuck and and I can't close the program - its completely not responsive. After force quit, a lengthy report is generated and I've attached one here.
When I go back to the program, it tries to start. The icon bounces a while in the dock, then stops. No windows are opened. When I try to force quit, the program appears to running normally in the window. A force quit does not generate the report.
In order to run the program again, I have to restart the mac.
What other information would help track this down?
73 de David KT5V
rumlog crash 1.txt
example of crash report
(686.19 KiB) Downloaded 403 times
rumlog crash 1.txt
Re: RUMlogNG crash after sleep
I heard about this before. I can't duplicate this issue with my hardware here, so I guess the combination of used hardware and software drivers are causing he problem. As workaround you should disable the sleep mode. Maybe I can stop CAT control before the mac falls into sleep.
KT5V David
Once I upgraded to 1.0.9, I've not observed this problem again. What combination of factors at play here is still a mystery, but for now problem is "solved". Looking forward to 1.1
73 de David KT5V
