States being populated with counties
N2TSQ
Unread post by N2TSQ »
Hi Tom, Great work! I note that the state field seems to be populating with the county information when data is returned from either hamqth or qrz. Have others noted this as well?
Re: States being populated with counties
There definitively a failure in the HamQTH.com part. The qrz.com part should not be affected.
I can't test qrz.com. I asked for a free of charge test account (just for few days) to test my software, but this was rejected.
Can you confirm, that qrz.com is working correct?
N2TSQ
Hi Tom, I just tried again. HamQTH returns the county field into the logbook, but QRZ doesn't even seem to retrieve the state into the "map" window on the right side and it leaves the logbook blank. I'm using the version 1.0.6 (29) if that matters. Happy to help sort this out if I can.
Can you post a screen shot of the qrz.com result pane please?
Here a fix for the HamQTH.com issue: http://dl2rum.de/RUMlogNG/RUMlogNG.zip
