width notes field
PG2W
width notes field
Unread post by PG2W »
I cannot make the width of the notes-field wider. When taking the right separationcolon with the mouse and slide it right a new (in my case S. RX) field appears.
The mouse cursor changes in a colon with only a right arrow instead of right- and left-arrow.
What can be done?
de Wouter PG2W
w8hap
Re: width notes field
Unread post by w8hap »
If you place your mouse on the separator for LOCATOR, left click, and then drag it to the right, the NOTE field expands. I hope this helps.
-Rob
There can be hidden (width = 0) columns. You have to move these away first. You will notice the change of the curser. Sometimes it indicates an arrow in one direction only.
