DXCC Edit - Duplicate Entries
K6LE
Unread post by K6LE »
When I populate my Download tab in Edit DXCC it is full of duplicate entries.
Of course if I load it in to my DXCC.rsd file I can't save it because it has multiple duplicates which came from the download.
What am I doing wrong?
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Re: DXCC Edit - Duplicate Entries
This anomaly seems to be related to the DXCC.rsd I am using.
I am going to start over with the current DXCC.rsd in the program package and see how it goes.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Well, starting from scratch with the default DXCC.rsd that comes with the latest RUMlog zip file solved most of my duplicate problem.
I am now missing 4 or 5 countries that I had added but I can add them again.
I will work with this "fresh" file.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
I've noted a bug in the up- and download routines. When you want to upload your changes before you downloaded the database on the server, all entries will be uploaded again. That's why there are a lot of double entries in the database.
K6LE
Ok, that makes sense.
Thanks for the answer. I thought I was doing something wrong.
Anyway, by reverting to the "default" DXCC.rsd and updating it, I seem to be fine now.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
