Winter Field Day Mod Needed
KI7BCL
Unread post by KI7BCL »
Apparently, the rules changed this year (as I just found out), and the field names for the contest MUST be named as indicated in the linked WFD Blog Post.
I got mine resolved, but it looks like this will be the rule in the future.
Specifically, the CLASS and ARR_SECT fields must be so identified in the Cabrillo and an exported adif file instead of just the stx and rtx strings.
https://blog.winterfieldday.org/2026/02 ... ample.html
Hope you can get this done for next year,
Fred KI7BCL
Re: Winter Field Day Mod Needed
Normally you use the Cabrillo format to upload a contest log. No need to deal with ADIF.
