Frequency stops following
pd0fk
Unread post by pd0fk »
Hi radio friends
I'm using RumlogNG 6.0 on my Imac connected to my Icom IC-756pro3 connected via by usb. When i start up everything is working well. RumlogNG follows the frequency of the Icom. Once i've made a qso, so after transmitting, the frequency gets blocked. It wont follow if I chance frequency and it will stay on the last frequency. I have to reset the CAt in the menu bar and then it works again for some time. But after having to reset it after every QSO it won't reset again and RumlogNG start to freeze completely. Then I have to force-stop the program and it wont start again. I have to restart the Imac.
I'm ru8nnig RumlogNG 6.0 on a Imac Retina 5K (2017)
3,4 GHz Quad-Core Intel Core I5
Radeon Pro 570 4 Gb
8 Gb 2400 Mhz DDR4
macOS Ventura 13.7.8
It also happened on the Imac with RumlogNG 5.19. Do more people have this problem? Or is there something wrong thit my settings? Or is my Imac not compatible? I hope that someone can help me out!
73's and kind regards, Fonsz (PD0FK)
Re: Frequency stops following
Seems to be RFI. use a better shielded USB cable.
pd0fk
Thank you for the fast reply and your great tip, Tom. Problem is solved! :D
