RUMtrol7000-RT 2.1 Beta 6 uploaded
Beta 6 is available for download: http://dl2rum.de/rumsoft/RUMtrol7K.html
I've changed slightly the way how the internal memory clipboard works. Now it is possible to select more than one channel, to use it for 'Cut", 'Copy' or 'Insert'. This was done for your convenience if you want to transfer data from one memory bank to another.
Please note the difference how 'Insert' and 'Paste' work. 'Insert' will insert the memories from the clipboard in the selected row downwards. It is important to know, that the latest memories ((99 and downwards) will be deleted. When using 'Paste", the selected memories will be overwritten by the data from the clipboard. When you have 3 memories in the clipboard and only 2 lines selected, only these 2 memories will be overwritten. When you have 2 memories in the clipboard but 3 lines selected, only 2 memories are overwritten.
For all these multiple line operations it is not required to select the memories in sequence.
Thanks Larry, K9LMM for the hint.
