RUMlog 4.4.8
RUMlog 4.4.8
• Net Control Window: It's possible now to delete entries (call signs) from the database, use the 'Delete' button
• More sun picture options, see the Window menu
• DX-Cluster login with username and password
• French translation - tnx Daniel, F6FLU
• eQSL User Database (AG-Members) added
• 6m Bandplan deactivated for DX spots, the mode computation on 6m was never working reliable
• Limited Fldigi support
• Failure removed, when opening older RUMlog log files
• Failure removed, when using RTTY with K3 for TX and cocoaModem for RX
RUMlog 4.4.9
When your transceiver sends frequency or mode data to often, Fldigi may slow down. Here is a version with less data transfer to Fldigi. No other changes were made. Thanks to Dave, K3DCW for the hint.
Re: RUMlog 4.4.10
  • qrz.com call sign look up works again - qrz.com does not provide the ww-locator (grid square) information any longer in the free service. That's why the stations can not be shown in GoogleMaps or GoogleEarth automatically. To see the map, you have to enter the locator manually.
  • The downloaded eQSL user database is being updated correctly now
g0vgs
Re: RUMlog 4.4.8
Unread post by g0vgs »
As always, thanks for the updates to the log, fantastic :)
I used the Net Control window today for the first time with the changes. It could so with a restore function of some kind. I had 2 stations in the net and I pressed the show button. This of course showed me the full database which is great but there was no way to get back to my log. I clicked on edit and then cancel which then presented me with a blank window so the stations I had logged had vanished. It would be nice to look at the net database but then to be able to return to the current list of net members.
73 Ian
Ian J Maude | G0VGS
K3s #10268
Re: RUMlog 4.4.8
Well, this will be a problem. Any more detailed thoughts of proposals? Maybe an extra table to show the full list?
BTW, in July and August I will be out of the country, then there is no time for the work with RUMlog. Currently I'm working on the qrz.com xml interface. I hope it's ready until the end of the month. This became required, because not all information are available in the free service.
Here a first screen shot, more data sets are available. I.e. the exact location of the station which one can be shown in the map.
