switch from filter2 to filter 1 in MWC contest
hanz
Unread post by hanz »
Hello Tom,
When i select a station from the contest band map the radio switches from F2 (500hz) to F1 (1k2Hz).
Is there a setting wrong?
Icom7610 cat via Ethernet.
73 hanz YL#JD
Re: switch from filter2 to filter 1 in MWC contest
You have to select your preferred filter in the TRX Preferences.
hanz
Thanks Tom,
I changed it under Voice keyer to F2.
Tested it now oke.
Vielen dank, alles gute.
73 hanz
