TRX#2 and FLEXRADIO 6600M
wu4g
Unread post by wu4g »
I've not found a way to get TRX#2 to talk to a second slice no matter if I'm using the radio front panel, or using SmartSDR running on Windows on same network. Discover only finds the same port that it finds for TRX#1. Is this a supported feature? If so, any tips on how to get it working?
Thanks & 73
Ron, WU4G
Re: TRX#2 and FLEXRADIO 6600M
You need two slices for one trx. One for RX, one for TX when in split. You need four slices to configure two transceivers.
wu4g
I had 3 slices going, A & B split, and C, but not the 4th. Created it and it worked. Don't know why I didn't try that. Thank you!!!!
Ron, WU4G
