Remove a Logbook
Jacques
Remove a Logbook
Unread post by Jacques »
Now retired so doing a progressive switch from windows ( no longer needed for work) :D to Mac so still experimenting before full changeover.
I created two logs to play with and now wish to delete one and finalise the set up?
From what I see these needs to be done via iTunes yet my MB air is on venture 13.3.& which apparently does not longer support iTunes ? so how do we delete a log ?
any pointers etc would grateful and apologies if its a basic question.
73s Jacques F1VEV - 9M2/G1BTU etc
Best 73s Jacques F1VEV
Re: Remove a Logbook
You are in the Mac? Select and use another file and drag the file to delete to the trash.
Jacques
Thank you things are so simpler on Mac 73s
