Incoming eQSL problem V5.12.1
va3cp
Unread post by va3cp »
I have installed V5.12.1 and am running into a problem with incoming eQSL's.
I use two logbooks with separate eQSL accounts.
Primary: VA3CP for home.
Secondary: VE3LJW for POTA activations.
After installing V5.12.1, the credentials for VE3LJW were copied into the LoTW/eQSL window in Preferences for the VA3CP account. The information has been corrected for VA3CP and I can send eQSL's out but get a "No such Username/Password found" error when trying to get incoming eQSL's. The Username and Password has to be correct to send outgoing rQSL's.
I went back to RunlogNG V5.0.3 for a test and cannot retrieve incoming eQSL's for the VA3CP account. VE3LJW works fine in V5.12.1.
macOS Monterey V12.6.3
RumlogNG V5.12.1
73, Dave, VA3CP
Re: Incoming eQSL problem V5.12.1
Make sure your location nick matches 100%. This error message may be misleading.
va3cp
Thanks Tom,
That was the problem. All good now.
73, Dave, VA3CP
