Few questions related to use of RUMlogNG
f5ukw
Unread post by f5ukw »
Rather than creating several topics, I think it would be easier to ask my 3 questions in same post.
After experimenting several challenger, I really think RUMlogNG is the best for now.
1. Is there anything we can do to customize a column? For exemple, it would worth having in bold the Callsign column to have the relevant information easy to read.
2. Is there a way to update a batch of QSO to set the QSL status? See attachement
3. How to set Credit Granted? Clublog is using the V letter for QSL status: https://clublog.freshdesk.com/support/s ... ue-v-mean-
So when I was used to export my log to Clublog I could set V as verified for all Lotw QSO. is there a way to do so ? https://clublog.org/dxccchart.php?call=F5UKW
Thanks for your time and reading!
Question 2
Question 2
Re: Few questions related to use of RUMlogNG
No
Select the QSOs in question and see the QSL menu. More options are not available.
You have to import the data from the ARRL: Menu-->QSL-->Import DXCC Credits
You can manipulate the status for each QSO individually using the QSO Edit function.
