A way to get both Name fields imported from QRZ?
SLively
Unread post by SLively »
I'm using QRZ and occasionally HamQTH to fill name, location, etc. fields for each QSO. I am having a problem with the name field, in that frequently there are two name fields, a first name and last name field, and only one, the first name, is being picked up in the log. I end up having manually add in the last name in the name field in the log. Is it possible to get two name fields so both fields from QRZ would transfer, or possibly get the contents of the second name field in QRZ appended to the contents of the first field in the log?
Re: A way to get both Name fields imported from QRZ?
No, the nick is preferred. When nor found the first name will be used. It's a logger, not an address book. You have to fill it manually.
SLively
Ok, I was more focused on keeping track of all the info, but your approach makes sense. I think I'll just ease up and run with just the nick name or first name, as you suggest. Thanks
