Editing a QSO doesn't stick until the 2nd time
k3gx
Unread post by k3gx »
I have RUMlogNG v5.7 running on MacOS 11.6.4 and have an annoying problem where when I edit a QSO, the popup window comes up, I make the changes, and then hit save - but the changes do not get saved until I open the contact up a second time, make the changes, and hit save again. Am I doing something wrong when editing?
Dave K3GX
Re: Editing a QSO doesn't stick until the 2nd time
Do you edit one or multiple QSOs?
Which field was changed?
k3gx
This happens when I edit one contact at a time. Yesterday, I was editing multiple fields in each QSO including location (city), grid square, and comments. When working SOTA, I like to edit the city to refer to the peak name, the grid square to the grid location of the peak, and put the point value in the comments field. I found that even just editing one of the user-defined fields, such as the SOTA reference, resulted in the same behavior.
Dave K3GX
One more:
Do you use the iCloud synced logbook?
Most probably the changed data are saved correct, but are shown wrong in the log table.
k3gx
Good point. Yes, I do store on iCloud. Does it take time for the entry to update when doing that?
No, it takes affect right away. All data are stored locally first.
When you observe it again, quit RULog and restart it. Check again. This helps me trouble shooting since I can't duplicate the failure.
N7YHF
Unread post by N7YHF »
I have the same issue--editing a single QSO requires two attempts about 80% of the time. I am most often changing the grid locator when WSJT-X doesn't populate it correctly. My logbook is an iCloud-synced one.
I am using RumLogNG 5.10 (544) on macOS 12.6.
Tab out of the field before you save the changes. When the changes are not seen, restart RL. Are the changes now visible?
shadow
Unread post by shadow »
I really enjoy using RumLogNG, it's a fantastic piece of software.
I have a similar issue however, sometimes it takes more than twice to edit the QSO. I've also noticed that if I'm scrolling the list of QSOs that it jumps / resets periodically. I stopped using iCloud syncing and both behaviors stopped.
I'm wondering if the iCloud syncing is happening in the background when the QSO is open, maybe a database locking issue?
--Marc
KC3TCT
Unread post by KC3TCT »
Hello.
I had originally set up to use the iCloud synced log but, somewhere along the way, switched to a local file. This past week, I had switched back to the synced log and had the same issue. I noticed that imports from WSJTX and FLdigi seemed to appear quicker but I would have to edit the info twice before the changes showed. I exported the log to a local file (in the iCloud directory) and the issue went away.
Cheers and 73,
Jim KC3TCT
