Search QSO window.
James
Search QSO window.
Unread post by James »
The QSO search window, it cannot be closed.
It can only be closed if the list of saved searches is empty.
I think it happens to me since upgrading from 5.0.3. to 5.1.3, but I'm not sure.
Also, when doing the update, the saved searches disappeared.
What did I do wrong?
73 de James.
James
Re: Search QSO window.
I return to this topic because it is a very useful window and I use it constantly with simple or somewhat complicated erepetitive queries (e.g. to select contacts for QSL, ...).
When I make a query, I hit the "+" button and it appears in "saved custom queries" as "New Query". Whether I respect the name or change it, there is no way to close the window (red button "and I must close RUMlogNG, losing the query.
In fact, I cannot save any queries and I have them written on paper to type every time I need them and it is a hassle.
This has happened to me for several versions until I have 5.3 (465) installed.
I have done a completely new installation (removing the app and renaming the ../Library/Containers/de.dl2rum.RUMlogNG folder and the problem persists.
MacOS: Catalina.
Is there any solution.
Best 73 for all.
Hi James,
I was not aware of this problem/thread. In case of a bug I would prefer a more direct conservation.
It will be fixed in the next version.
73 de Tom, DL2RUM
