eQSL and attached accounts
ke3gp
Unread post by ke3gp »
I recently moved and when I went to update my info in eQSL, I had to create an attached account which has broken RumLog uploads and downloads since the login page always gives you a choice of which account you want to log in to. Is there a better way to do this other than a manual export and subsequent import into eQSL???
Re: eQSL and attached accounts
You can set a Location Nick for different locations using the same account.
ke3gp
I had done that and it still wasn't accepting it. I wasn't able to change my nickname on eQSL. I ended up setting a different password and that worked. Now, they have manually updated my QTH so I will try going back to one password and see if it works by changing just the nickname.
