Page 1 of 2
QSO Upload Utility not working
Posted: Tue 20. Oct 2020, 07:55
by James
Since I installed Rumlog version 5, the QSO upload utility stopped working.
In the utility window, it connects to the different sites without apparent error but then, the uploaded QSOs do not appear in the window utility and in the sites (QRZ, HRDlog and HamQTH). The rest of the sites (Clublog and eQSL) I have deactivated, the same Rumlog does.
Does anyone have the same problem or any idea?
Re: QSO Upload Utility not working
Posted: Tue 20. Oct 2020, 09:06
I use it for hamqth.com and hrdlog.net only and this works fine even under version 5.
Posted: Wed 21. Oct 2020, 21:55
by James
Perfect , it works with hamqth.com and hrdlog.net, without QRZ.com.
Is it expected to work again with QRZ.com?
Perhaps the most important of the 3.
Thanks Thomas.
Posted: Wed 21. Oct 2020, 22:00
You should post a screen shot of the qrq.com tab. What is it showing?
Posted: Thu 22. Oct 2020, 08:07
by James
Thomas, says nothing.
The other 2 include the uploads.
It stopped working, just upgrade RumlogNG to V5.
I don't know if it's a coincidence.
No other software upgrade on i Mac for several weeks.
Posted: Thu 22. Oct 2020, 09:03
Download an older version from here: app.php/downloads and try again.
Posted: Thu 22. Oct 2020, 10:01
by James
From this site, it leads me to the App Store, and there is the version that I have installed 1.3.2 (17).
So how do I install an older version?
Posted: Thu 22. Oct 2020, 10:48
app.php/downloads
Maybe you have to scroll down to see the full page.
Posted: Thu 22. Oct 2020, 14:23
by James
Yes, I saw it before.
From previous versions it only exists for RumlogNG and Rumtrol, not from the utility, which is what I was referring to.
If the solution is to uninstall RumlogNG v5 and install v4.7, I prefer v5, no problem.
Thanks Thomas.
Posted: Thu 22. Oct 2020, 14:50
As far as I understood the upload stopped working with RUMlog version 5, see your first post. That's why I asked you to test 4.7 again. No need to uninstall, just run the old version from the download folder.
