QSO info from qrz.com
James
Unread post by James »
With version 5:
1.- When supplementing QSO data with information from qrz.com, the information is confusing. At least 2 lines appear for each contact, many times in red.
2.- In the station information window, the information often does not appear if you retrieve information from qrz.com. This I cannot reproduce because at the moment it does not happen to me, it is random.
I thought that all this was a specific problem of qrz.com and I have waited 1 day to report it, but it remains the same.
It happens to me since I installed version 5 of RumlogNG.
Does it happen to someone else?
Attached screenshots of point 1.
A screenshot is about a single callsign and what happens is that a first line with the callsign only appears and the other line appears the data Ok.
and the other screenshot is a 4 callsign query.
By the way, a very good option that the QSOs are incorporated automatically from N1MM.
I have tested it and it will really be a very useful help for large contests.
Re: QSO info from qrz.com
Confirmed. Looks really crazy, I have to check. It seems HamQTH is not affected.
James
No, QTH seems not to be affected, check it out.
Thank you,
James
Perfect and fast, now yes.
By the way, "QSO upload utility" has stopped working for me.
I always have "Listen to UDP N1MM contact" activated and I update perfectly in qrz, HRDlog and Hamqth (Clublog and eQSL performed directly in RumlogNG).
I thought it was because I have the RumlogNG option "QSO received from N1MM" activated, but it has nothing to do with it, I think.
Thanks.
