Import old rumlog .rsd logs
dh1tw
Unread post by dh1tw »
Hi fellows,
I found some older logs which were, I believe, created in Rumlog (the older version). The file extension is `.rsd`. I was looking for a way to convert or import those old logs into RumlogNG? Having a look into the file with the text editor, it seems that it's an sqlite database.
Thanks & 73,
Tobias
DH1TW
Re: Import old rumlog .rsd logs
The function to import RUMlog classic logbook files was deleted in version 4.0. You have to use an older version from here: app.php/downloads
When the file is not in SQLite, you are in trouble. Then it‘s very old.
dh1tw
Thanks for the swift reply Tom. Using version 3.6 did the job. I was able to convert all logs.
Thanks again!
73 Tobias
HB9OBB
Unread post by HB9OBB »
I have an old log file which i would like to pass over to the latest RUMlog version.
So I followed the suggested path: install an old version load the .rsd file, export it as ADIF and re-import it in the new RUMlog.
I installed version version 3.6.2, created a "new with RUMlog classic file" and tried to import my old .rsd file.
It fails with error "Not a classic RUMlog file"...
Any idea?
73 Daniele
HB9OBB
Maybe it's a very old file? E-mail me the file for examination.
HB9OBB
Just sent you my old file.
Thanks ahead :-)
