SRX/STX Strings
K6LE
SRX/STX Strings
Unread post by K6LE »
When I import a contest ADIF file I wind up losing the contest strings.
Here is an example of a AIDF I just imported.
<call:5>N1BAA<qso_date:8>20090131<time_on:6>200600<freq:8>14.08000<band:3>20m<band:3>20m<mode:6>PSK125<rst_rcvd:3>599<rst_sent:3>599<
srx_string:3>268<stx_string:1>2<qsl_via:4>LoTW<qsl_rcvd:1>N<qsl_sent:1>Y<eor>
I wonder if it would be possible to add the "stx_string" and "srx_string" data columns?
Actually, if they at least wound up in the "Note" column would be OK too.
Rick - K6LE
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Re: SRX/STX Strings
The <stx_string> and <srx_string> tags are used for contest exchange information. In RUMlog are no fields provided to store these information. RUMlog is not useful in a contest. Why would you store contest control numbers in your logbook?
K6LE
Re: SRX/STX Strings
DL2RUM wrote:The <stx_string> and <srx_string> tags are used for contest exchange information. In RUMlog are no fields provided to store these information. RUMlog is not useful in a contest. Why would you store contest control numbers in your logbook?
I guess the easy answer is because I want to!
As an example: Say I work someone a few months after the contest and we are chatting about the fact that we worked each other in the xxxxx Test, it might be nice to be able to recall his and my QSO numbers. Or, another example, if we worked in the Sweepstakes I would have his first year licensed in my log entry, more fodder for conversation.
Not a big deal.
Rick
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
