Associating a callsign with a specific dxcc entity
VE3MM
Unread post by VE3MM »
I worked TX5T (FO/A) and the contact logs as DXCC ?. I tried adding TX5T to the preferences DXCC exception list but it does not associate the change the QSO information to FO/A. Can you please let me know the proper procedure for this.
Re: Associating a callsign with a specific dxcc entity
VE3MM
Thanks Tom. I checked to make sure the latest club log file is installed and TX5T is correctly associated with FO(A).
If I log a new contact with TX5T it shows up with the correct DXCC entity.
However I have two other contacts with TX5T and they still show ?? in the DX entity column.
Is there a way to get the entities recognized? I tried restarting RumlogNG but this didn't do it.
Rick ve3mm
All QSO and DXCC entity information are stored within the database record. There is no automatic update.
From the document linked above:
When you have logged a QSO already before you made changes, you have to recalculate the DXCC entity for all affected QSOs. To do this, select the affected QSOs and use Menu–>Logbook–>Recalculate DXCCs.
VE3MM
Hi Tom
This worked fine. Thanks for your help. Have a good day.
Rick ve3mm
