RUMlogNG version 3.8
RUMlogNG 3.8 is available here:
RUMlog 3.7 and newer requires macOS 10.11 (El Capitan)
  • Change: A dx spot already worked in this slot will not be announced again via notification or voice
  • Fixed: DX-Spot are shown correct when RUMlog uses local time - Tnx Mattia, IZ3WTP
  • Fixed: On a system, where RUMlog was never running, it was not possible to open an already existing logbook file - Tnx Andy, DL1AKP
  • New: Option added in the dx-spot window to hide already worked stations
  • New: IC-7300 control window shows the manual notch filter frequency
  • New: Solar Activity Status Window (http://www.n3kl.org/sun/status.html)
  • New: Support für Spanish TPEA award
  • New: New York QSO Party
  • New: Iowa QSO Party
  • New: Illinois QSO Party
  • New: Thüringen Contest
ik2eae
Re: RUMlogNG version 3.8
Unread post by ik2eae »
I use RumlogNG 3.8 and I have a problem on dx spot windows. If I use "ALL" to see the incoming spot the column "Hdg." is's show correctly but if I use any other option, (20m, 10m 6m...) I can see two "Hdg." and one of them are blank and I can sort only the first two column (DX de or DX Call). OSX 10.13
I have seen this before. Please check (using the mouse) if there is a column set to a width of zero. Use the contextual in the table header menu to toggle each column.
It seems, macOS doesn't like columns with zero width in this context.
K6LE
Re: RUMlogNG version 3.8 - LoTW QSL's
Unread post by K6LE »
For some reason, that I think started with 3.8.1, I no longer get new confirmations from LoTW.
It says "no new QSL's" even though I know by looking at the LoTW page that new ones have come in.
For now I am manually confirming the QSO's in RUMlogNG.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
No Problems yet.
But there is another issue under High Sierra. Open the Preferences window and check if your prefs are set. When not close RUMlog and restart.
K6LE
DL2RUM wrote:But there is another issue under High Sierra. Open the Preferences window and check if your prefs are set. When not close RUMlog and restart.
I rechecked the Preferences.
As an experiment I changed the password in the preferences LoTW section and it came back as an incorrect password. So, after changing the password back to the correct one it accepted it but says "no new QSL's" even when I know there are new ones.
I also tried it on my 2016 MBP and it also said "no new QSL's"
I'll check it again when I see from LoTW that there are some new QSL's received.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Rick,
can you provide a screenshot of your LoTW settings please?
K6LE
One thing I notice is that the download date never changes.
Makes me wonder if the format for the date is correct.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
That's why I want to see a screenshot.
K6LE
Did the screenshot come through?
I tried to change the date format but it won't let me.
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
