Virtual serial cable
Posted: Wed 19. Jul 2017, 23:16
by SM0MDG
After many years with Mac as my primary work PC I am now playing with it in the shack too. I am trying to make it work with my SunSDR2 QRP transceiver using a virtual serial connection between the logger and the radio's control softare. It kinda works as I am able to update the logger with the tuned frequency by doing a reset of CAT, but RUMlog does not automatically follow the radio. In my setup I am using AirconsoleOSX to create a "virtual nullmodem cable". This setup works fine with MacLogger and fldigi, but not with RUMlog. The CAT protocol of SunSDR2 PRO is compatible TS-480. All ideas welcome!
73 de Björn
SM0MDG
SE0X
Re: Virtual serial cable
Posted: Wed 19. Jul 2017, 23:25
As far as I know, the TS-480 uses RTS/CTS for flow control. See the CAT manual.
Posted: Thu 20. Jul 2017, 09:12
by SM0MDG
I tried with and without RTS/CTS flow control, neither works.
It works well when controlling the radio using flrig (and MacLogger), what could be different in the setup with RUMlog? I am not so familiar with flrig, but can I use flrig as a gateway between the radio and RUMlog?
Or maybe something with AirconsoleOSX is not working the way RUMlog expects. Are there other virtual serial emulators for Mac that I can test?
Can I use flrig as a work around, is it possible to access flrig with the logger while it is controlling the radio?
Posted: Thu 20. Jul 2017, 09:36
Is it not working in both directions? Can you set the trx from RUMlog?
Posted: Thu 20. Jul 2017, 09:51
by SM0MDG
I see the transceiver in RUMlog and when I click the band map the transceivers frequency moves there. So it kinda work when I "push it" by using reset CAT. But RUMlog doesn't follow the TRX.
I tried an alternate solution by hooking up a TS-590S via USB to the Macbook. It works the same way. Initially I had the same problem, but when double clicking a spot the problem was resolved. Very strange. Unfortunately this "trick" doesn't work with the TS480 compatible SDR TRX.
Posted: Thu 20. Jul 2017, 09:55
RUMlog uses the AI2; (Auto Info) command to fetch trx data. Is this command implemented in your emulation?
Posted: Thu 20. Jul 2017, 15:18
by SM0MDG
That seem to be the problem. The SDR software doesnt support the autoinfo command.
Any possible workaround?
Posted: Thu 26. Oct 2017, 11:32
by VE3MM
Hello group
I have a Sunsdr2Pro as well and have encountered the same issue connecting to Rumlog. The computer is an I5 27" Imac running Mac OS Sierra. In my case I am using two usb to serial adapters with their tx-rx lines cross connected together.
I am only able to force a frequency update in Rumlog by selecting the reset cat #1 command.
Has there been any solution found to the lack of an autoinfo command in the Sunsdr2Pro protocol?
Thanks for any help.
Rick ve3mm
