Print QSL Labels to ADIF - Export option as ADX?
Franz
Unread post by Franz »
Hi all,
I am considering printing QSL Cards in batch with an external software locally. This can be done using the ADIF export option in the paper QSL card print dialog. Unfortunately ADIF seems to be quite painful to import compared to the newer xml- based ADX. Would it be possible to add an option to export ADX? Maybe just a second button in the print dialog.
Re: Print QSL Labels to ADIF - Export option as ADX?
Unfortunately, the ADX format is very rarely used.
But there is a workaround:
  • Sort the logbook table by Paper QSL status
  • Select all QSOs with QSL status W and R
  • Go to Menu-->Logbuch-->Export selected QSOs as ADX
To update the paper QSL status just use the provided QSL print function and print as PDF.
