IC-7610 Control font crowding
VK2HEY
Unread post by VK2HEY »
Hi there,
Firstly, this software is so beautiful that it's hard to run away from. I use it on a very old 2009 iMac with a 27 inch screen and High Sierra 10.13.6.
Today I updated RUMLogNG from 5194 to 520 and have noticed some crowding of the button labels, but only with the IC-7610 control window. Changing the window size or shape makes no difference. The issue does not seem to occur anywhere else in the software.
Thanks!
Re: IC-7610 Control font crowding
This is due to major changes in macOS26. I was able to successfully test it with macOS 15, but not with older versions.
Unfortunately you have just these two options:
  • Downgrade to RL 5.19
  • Upgrade macOS
Older RUMlog versions can be found here: app.php/downloads
VK2HEY
Copy. Thanks!
PE2V
Unread post by PE2V »
FYI only. Same here on macOS 10.15.7 Catalina
