DXCC worked NOT confirmed
Jacques
Unread post by Jacques »
Good morning
Is there a way to see or preferably print a list of DXCC worked but not confirmed ? I can see the numbers in the DXCC entities section but a list would be more workable for me .
Thank you for any advise
73s
Re: DXCC worked NOT confirmed
See Menu-->Window-->Search Entities and make your selections.
You can print nearly all tables in RL. Select a row in the table in question and select Menu-->Edit-->Print. For wide tables it may be required to scale the output in Menu-->Edit-->Paper Format
Jacques
Perfect Thank you very much 73s
