I am trying out RUMlogNG, version 5.19.4 (684) from the App Store, and everything is working nicely except lookups via QRZ.com. I have the correct username and password (I have checked, re-check, triple-checked etc) in the settings but lookups give me the following:
Error 3 parsing qrz.com:
Username/password incorrect
I get the same error if I just click the little triangle that opens up the lookup with. Or if I tab to a different lookup provider and then back to the QRZ.com tab.
My QRZ.com XML subscription is current and I've tested my login in other apps such as MacLoggerDX which works fine.
I am running RUMlogNG on an Intel Mac running Sonoma 14.7.6.
Doug VE1LG
Cannot Login to QRZ.com
Re: Cannot Login to QRZ.com
So I used mitmproxy to capture and view the https packets to/from xmldata.qrz.com with both MacLoggerDX (working) and RUMlogNG (not working).
MacLoggerDX uses
?username=the-callsign-here;passwd=the-password-here;agent=the-agent-here
Also, in my specific password I have special characters. MacLoggerDX escapes them all.
RUMlogNG uses
?username=the-callsign-here&password=the-password-here&agent=the-agent-here
RUMlogNG escapes most of the special characters in my password except for ; and :
I doubt the use of & vice ; to delineate GET parameters matters, but not escaping the semi-colon and colon in my password certainly does.
I will change my password to not have a semi-colon and colon and report back here.
MacLoggerDX uses
RUMlogNG uses
Yup, can confirm. Replaced the semi-colon and colon in my password with alpha characters on qrz.com, then made that change in RUMlogNG as well and it is now working.
Thanks for the hint Doug.
In fact, RUMlog fights with this problem since the beginning. I have to dive in it in again.
Ironically I had the same issue with my own Android app for QRZ lookups. So this should have been the first thing I looked at but it slipped my mind.
It seems to be a common problem due to different interpretations of the standard. Apple writes here: https://developer.apple.com/documentati ... guage=objc
RFC 3986 specifies which characters must be percent-encoded in the query component of a URL, but not how those characters should be interpreted. The use of delimited key-value pairs is a common convention, but isn’t standardized by a specification. Therefore, you may encounter interoperability problems with other implementations that follow this convention.
It would be nice if standards were written such that they did not need interpreting. But a perfect world does not exist
