Duplicates from RUMlogNG to QRZ
it9ggg
Post by it9ggg »
I saved my log from RUMlogNG and imported that to QRZ. The result is more than 1200 duplicate QSOs. The dupes are always 1-2 minutes later than the existing entry.
How can I remove the duplicates? The number is so high that a manual removal would be a very long task.
IT9GGG
it9ggg
Re: Duplicates from RUMlogNG to QRZ
Post by it9ggg »
I asked for help from QRZ support; they said that somehow, RumLog changed the log time of 1 minute and therefore posted duplicates (several hundred) on the QRZ database that accepted them because of the different time stamps. It seems there's one unique solution: cancelling duplicates by hand. Several days of work!!!
Thanks RUMlogNG!!!
it9ggg
Post by it9ggg »
Manually removed about 900 duplicated QSOs. I could not figure out how and why RUMLog duplicated some of them (about 1900+ correct QSOs before the disaster).
It's very sad to see that nobody took care of replying to this thread. I'm abandoning RUMLogNG, of course, but I still remain curious: Why did it happen?
I'm pretty sure I did everything in the right way. I exported the log file from RUMLog and imported it into the QRZ website.
IT9GGG
Post by DL2RUM »
RUMlog doesn't change the log time by itself!
It seems nobody has an idea what you have made. Why do you upload your log twice?
it9ggg
Post by it9ggg »
Upload to qrz from the app was not working so I exported my log to an ADIF file, uploaded that to the qrz website and it did change the times of the QSOs, thus adding tons of dupes, that’s a fact although I do not understand why and how. I can report the mail from the qrz support they arrived to my same conclusion: something happened with time in the exported ADIF log file
it9ggg
Post by it9ggg »
BTW: I've just seen on the Apple store page of RUMlogNG that there has been a recent fix:
"Fix: ADIF export - QSO_DATE_OFF may be not correct - Tnx todivefor".
It seems I was not the unique one to meet this issue, thanks to todivefor from me too :)
Perhaps I could give RUMlogNG another try (indeed I used that for a while in the past without any issue)
Post by DL2RUM »
No, this was another issue. There was a problem with a specific setup of the user fields when your QSO start date was different than QSO end date, around 00:00z.
