Mode and SubMode
Jacques
Mode and SubMode
Unread post by Jacques »
Hello
Am I correct in assuming Rumlog cannot have mode MFSK and FT4 recorded I have gone through FAQ etc but found no information .
I import my adif with mode and submode but all the logbook shows only FT4 and S Mode column empty
Thank you Jacques
Best 73s Jacques F1VEV
Re: Mode and SubMode
There is no Sub Mode column. Only one mode entry can be saved. When both Mode and Sub Mode information are found in the ADIF, the Sub Mode will be saved.
Jacques
Noted thank you I miss-took "s'mde" for submode so what is s'med Cheers
