Missing Power Field?
G7ORH
Unread post by G7ORH »
Hi, I am new to RUMlog so please excuse me if this has been addressed. I use a MacBook, iPad and iPhone for logging. On the iPad, if I set the default power to power in watts, I do not get an input field. Is this correct or am I missing something?
Re: Missing Power Field?
Press the Details button for more options.
G7ORH
I select ‘Set Details’ and enter power in watts and ensure that the entry has a blue tick, select Okay and nothing happens on the logging screen
When you have made your selection, you shroud see it:
G7ORH
I does not display if I select ‘Power in Watts’, works if ‘High Power’ is selected
Can you provide screen shots?
G7ORH
I did move the blue tick down honest!
When you select Unknown, no power information will be saved/shown!
G7ORH
Apologies Tom,
I got the photos mixed up, doh,
I select ‘set details’, change to blue tick on power in watts and enter a value. Press okay and back to the logging screen and nothing is displayed.
Okay, I see. It may be a little bit tricky to take over changed data here.
  • Enter the Power in Watt
  • Select another option, i.e. QRP
  • Reselect Power in Watt
