QRZ station info lookup going wonky
n8sqt
Unread post by n8sqt »
Greetings,
Over the last few days, I noticed a new "issue". The QRZ lookup appears to be doing so about 10 times for each time window of WSJT-X. The actual data transfer between the two programs seems OK (i.e., double-clicking on a WSJT-X CQ line causes the call info to appear in RumLogNG).
Here's a video of what's happening: https://www.icloud.com/iclouddrive/02cR ... 2.58.05_PM
Here are my RumLogNG settings:
and my WSJT-X settings
Nothing out of the ordinary there. At least I don't think so.
I originally had WSJT-X going to the broadcast address, then GridTracker relaying from 2237 to 2238 and RumLogNG listening on 2238. The reason for this is that I also have HamClock running on a Raspberry Pi which needs to listen for the UDP packets as well. I noticed the odd lookup behavior with this configuration so I figured I'd remove HamClock and GridTracker and try the above settings to eliminate as many variables as possible. The recording above is with only the two programs running (WSJT-X and RumLogNG).
Has anyone seen this? Any thoughts on what settings to change?
Thanks!!
Bob N8SQT
n8sqt
Re: QRZ station info lookup going wonky
Forgot to include the versions:
RumLogNG: 5.11.3 (563)
WSJT-X: 2.5.4
n8sqt
I attached some Wireshark scans for localhost, broadcast, and multicast settings over on WSJT-X.
Happy New Year!
Bob N8SQT
N8SQT wireshark traces.zip
(56.92 KiB) Downloaded 213 times
There is a problem in the latest versions with the WSJT-X integration. An updated version is currently in the Apple review process.
n8sqt
Thanks for the update. I'll keep an eye out for the new version.
n8sqt
That did the trick! v5.11.4 is clean. Thanks!
