CQWW contest
g0vgs
CQWW contest
Unread post by g0vgs »
Just trying to make a plugin for CQWW SSB this weekend which I have pretty much done. I have not found a way to score ones own DXCC properly though. It is not worth any points but is worth a multiplier. Is there a way to do this?
73 Ian
CQWW.plist
(7.16 KiB) Downloaded 590 times
CQWW.plist
Ian J Maude | G0VGS
K3s #10268
g0vgs
Re: CQWW contest
OK, I have it working apart from one thing. I have set an exception for G to score zero points but act as a mult of 1 as per the rules. strangely though, GW, GD etc now score properly but do *not* get the zone multiplier. I am stuck on this one at the moment.
73 Ian
CQWW.plist
version 1.2
(7.18 KiB) Downloaded 658 times
CQWW.plist
version 1.2
Ian J Maude | G0VGS
K3s #10268
Re: CQWW contest
For the CQWW is no plug in required. This contest is hard coded in RUMped. Just select this contest, when creating a new log file.
g0vgs
Re: CQWW contest
Aaaah, this is WWDX? Sorry I was not expecting that :) BTW, in the drop down setup box for the log, you have Passwort which should be password in English.
73 Ian
Ian J Maude | G0VGS
K3s #10268
Re: CQWW contest
:D
I've not checked the latest rules, I hope the scoring in RUMped is still correct.
'Password' will be corrected in the next version, Tnx
M0JEK
Re: CQWW contest
Unread post by M0JEK »
Lernen Sie, Deutsches zu sprechen. Dann ist es nicht ein Problem :lol:
73 de André, M0JEK
g0vgs
Re: CQWW contest
M0JEK wrote:Lernen Sie, Deutsches zu sprechen. Dann ist es nicht ein Problem :lol:
Now now Monkey :) BTW, what kind of cat is that?
73 Ian
Ian J Maude | G0VGS
K3s #10268
