When I have the band map open and use it to select a spot, after one or two selections the application locks up with a spinner. Also happens in contest mode.
This doesn't seem to happen if I don't have the band map open and select from the DX Spots window instead.
I can send you a dignostic report from Consoel and also a cras report generated after Forced Quit. What is the best way to send them?
Leo
Lockup with Spinner after selecting from Band Map
Re: Lockup with Spinner after selecting from Band Map
E-mail the crash / spin reports with a screen shot of the band map. Which TRX do you use?
The TRX is a FTDX1200. I'm testing now with a TS-480 and so far it seems more stable.
Which email do I use? I can't see one.
okay I see the email icon
Any thoughts on this?
I have since upgraded to a FTdx101 and this radio has the same problem. It is only with the bandscopes - the DX spots dialog works fine. So at this time I am not using the bandscopes.
Could it be a baud rate issue?
I'm not able to reproduce this without a trx. Can you provide a screen shot of the band map window?
