first of all, thanks again for this great piece of software!
I got my IC-705 and connected it to RumLog. Via USB it works flawless, but there is a lot of noise and qrm when I connect the cable. Because of this and to reduce the cables to the 705, I tried Bluetooth. I set up everything according to the manual and some hints here in the forum. The first connection works always and everything is fine. But when I do a change of the bands, e.g. to 30m or 20m (any band) after one or two changes, the 705control window freezes (still showing the bandstack). The 705 switches to the band though.
I have to close the CAT connection then and reopen it again. There is a 50% chance to get it work. But I have to close Rumlog than to get it working again. But after the next incident like this, RUMlog does not even start anymore. The Icon just jumps at the taskbar.
There is no error prompt or anything I could provide to debug it so far. To get it running again, I even has to reinitialize the BT settings on the 705, too.
My machine is a MacBookPro M1 running the latest Monterey OS.
Any idea or can I provide any further info to solve this?
USB would be OK, but like I said it brings a lot of QRM (any idea to solve this, too?), but BT would be much more convenient. And since it seems to work for most users, I hope to get it right at my Mac, too.
Uli
DK5ZU
Bluetooth and IC-705 crashes RUMLog
Re: Bluetooth and IC-705 crashes RUMLog
I forgot to mention, RumLogGo on my iPhone works flawless with the 705 connected to BT
Where do I find it?
It should be presented after the crash and later you find it in the Console application. Just drag and drop the report out of the window, do not copy and paste the report text.
Thanks, I've sent a mail with more details and a report.
Uli
Uli
