List of supported contests
Can you point me to the rules written in English?
PE2V
Unread post by PE2V »
DL2RUM wrote: Tue 9. Nov 2021, 16:48 Can you point me to the rules written in English?
Hmmm no, sorry. Only Dutch. I have to translate it for you....
Reglement-VERON-DAC-VHF-UHF-SHF-V2019.pdf
(85.71 KiB) Downloaded 1561 times
PE2V
Hereby :) the rules in English...
Rules-VERON-DAC-VHF-UHF-SHF-V2019-ENG.pdf
(60.55 KiB) Downloaded 1604 times
PE2V
Some notes from the contest manager:
"Contest rules for the DAC are based on those of the NAC (Nordic Activity Contest)"
"Score calculation: For the DAC, this is the sum of the number of miles worked + 500 bonus points for each unique locatorsquare worked (e.g. JO21, IO91)."
"QSO input fields: For the DAC, NAC you only need to exchange Callsigns, RST and Locator. However, we work quite a lot of English stations from the Netherlands and there is an exchange of serial numbers. So in the logging program we also have to write down the serial numbers. In the Sent serial field you simply number each QSO with 1, starting with 001. At UK stations you pronounce this number, but at other stations you do not. Vice versa in the Received serial field at UK stations write down the given serial number at the other stations always 001. Any serial numbers in the log we ignore in the contestrobot when it comes to the DAC."
I will not support the serial number for the DAC. If you need a serial number, use another contest template.
PE2V
DL2RUM wrote: Wed 10. Nov 2021, 14:12 I will not support the serial number for the DAC. If you need a serial number, use another contest template.
No problem! I agree! For me it feels like combining two contests (DAC and UK contest). So leaving the serial number out is fine!
hanz
Unread post by hanz »
Dr Tom,
The ok/om contest asked if there were more logging progs supporting them.
I send an email that rumlog does.
They added it to the list.
many thanks hanz.
DO7OY
Unread post by DO7OY »
Hello, is it possible to add the District R Contest to the contest list?
please find the Link to the Contest description:
https://www.darc.de/der-club/distrikte/ ... chreibung/
Thank you very much for your help!
best regards Johanna DO7OY
vy 73 de Johanna, DO7OY
DO7OY
DO7OY wrote: Tue 11. Jan 2022, 18:52 is it possible to add the District R Contest to the contest list?
Tom/DL2RUM?
n0uk
Unread post by n0uk »
Thanks for your ongoing support for your excellent RumLogNG software.
I think I asked on this a couple of years ago but too soon to the contest date.
Would you please consider adding support for the annual US Minnesota QSO Party. It occurs each February and complete rules may be found at https://www.w0aa.org/wp-content/docs/mn ... _Rules.pdf
Thanks!
Chris, N0UK, G4JEC
