Data export and import version 3.4 and newer
Starting in version 3.4 new export and import routines are used.
Airdrop and iCloud Drive are supported out of the box. Please read the attached document carefully.
Data Exchange.pdf
(329.81 KiB) Downloaded 1017 times
Data Exchange.pdf
kbell101
Re: Data export and import version 3.4 and newer
Unread post by kbell101 »
Hi Tom... Thank you for all you do. I'm still discovering features.
PE2V
Unread post by PE2V »
Hello Tom, I purchased RUMlogNG2GO today..... and I tried to import the logbook.... and I did something wrong (yes, stupid me). Is it possible to remove / delete / erase the whole logbook in 2GO? So I can upload the log again? there are a lot of duplicates nog..... :? :roll: :cry:
But.... it works great over AirDrop!!
When you have a RUMlog file from the Mac, just copy and use the log file. No need to deal with ADIF.
You can always create, delete or change logbook files:
iPad: Log Settings
iPhone: Settings-->Log settings-->Logbook
PE2V
Found it... (stupid me again hehe).... create new logbook file, delete the old (wrong) one.... :mrgreen:
PE2V
DL2RUM wrote: Wed 8. Apr 2020, 15:23 When you have a RUMlog file from the Mac, just copy and use the log file. No need to deal with ADIF.
Thanks!
Ok, and this will overwrite the whole log or does it add new entries only?
PE2V
Ah, ok! That's nice... all settings are copied too when using the RUMlogNG rlog file... :D
Only question... how to synchronize?
DL2RUM_Tom
Unread post by DL2RUM_Tom »
No sync yet, you have to exchange the file.
PE2V
DL2RUM_Tom wrote: Wed 8. Apr 2020, 16:03 No sync yet, you have to exchange the file.
Only ‘share’ the file over AirDrop? I’ll test it tonight. I’m happy... :) ;)
PE2V
Works fine! Just tried and the on-screen message is clear: "File exists already, Do you want to overwrite existing file? Overwrite logbook / Cancel"
