Filter DX Spots - Exclude Digital Modes
wb2pkr
Unread post by wb2pkr »
I would like to suppress all digital mode spots showing up in the DX Spots window as I only operate phone and CW.
In the DX Cluster Preferences tab, I have selected only CW and Phone. I have left Data unchecked.
Unfortunately, most spots for digital modes are showing up in the cluster with the Mode as Phone with a descriptor of the specific digital mode in the Note Field.
Is there any way to suppress these spots in the DX Cluster Window?
DL2RUM_Tom
Re: Filter DX Spots - Exclude Digital Modes
Unread post by DL2RUM_Tom »
Make sure you have set your band plan correct.
wb2pkr
Tom, Would you please be more specific? Are you referring to the QRGs tab in preferences?
Yes, RUMlog determines the mode from the frequency. In the QRG settings you cab adjust the three band segments.
wb2pkr
Ah! Understood. Interesting approach. So long as folks adhere to the band plan, this works. Thanks.
