tqsl Error, Command systax error
ea7tb
Unread post by ea7tb »
For a problem I had to format the HD. I installed the program again, everything works fine. I have the following problem, with the rise of QSOs to LOWT, the message appears: "tqsl Error, Command systax error".
It works well the download of the confirmation of the QSO from Lotw.
Some help?
Version 4.0.5 (289)
Mojave 10.14.2
Greetings.
Manuel EA7TB. 73'
Re: tqsl Error, Command systax error
You should try to upload a single record. Do you get always this error?
ea7tb
Hi.
It does it with any registry, send them separately.
Greetings.
Manuel EA7TB. 73'
Recheck the station name.
ea7tb
I have done what you have indicated, I still can not upload the QSO, but I can download the confirmed ones.
Manuel EA7TB. 73'
Let the fields Station location and Signing Password empty.
ik5zve
Unread post by ik5zve »
Had the same problem;
Solved with this procedure; TNX
NN7M
Unread post by NN7M »
Thanks for the walk through. Helped me with LOTW in new install -- new to me MacMini.
Ryan NN7M
